Hi hoping someone can help I need a replacement radiator for my 1991 2.0i maestro I’ve tried having mine recored but no one can find a replacement core does anyone know of any company’s that supply or make to order new ones thanks in advance
2.0 EFI radiator
If you're stuck and can't get one you can replace with an mgf radiator. You will only need to re-locate the lugs that fix it to the front of the car. All else will fit1958 Ford Consul Convertible. I love this car
Originally posted by Andycl85 View PostJust one more question is the fan switch the same thanks1958 Ford Consul Convertible. I love this car
On this thread, post 31, you will need to cut, move an reweld the locating points on the mgf rad, all else is the same https://maestro.org.uk/forums/forum/...mg-montego-efiLast edited by Jeff Turbo; 26th September 2022, 16:32.1958 Ford Consul Convertible. I love this car
I have fitted a MGF rad to a diesel Montego, The fan switch was a pain. The MGF dose not seem to have a fan switch so you will to make sure the rad you order has a place for one to go, (many don't) and drill it out to 22mm. The clip maybe different, I needed one of these, https://rimmerbros.com/Item--i-CDU1502
Originally posted by robert1 View PostI have fitted a MGF rad to a diesel Montego, The fan switch was a pain. The MGF dose not seem to have a fan switch so you will to make sure the rad you order has a place for one to go, (many don't) and drill it out to 22mm. The clip maybe different, I needed one of these, https://rimmerbros.com/Item--i-CDU1502Last edited by Jeff Turbo; 29th September 2022, 13:25.1958 Ford Consul Convertible. I love this car
