As per title - no joy from the stalk switch but hazards come on just fine.
Flasher unit?
If the hazards work, then flasher unit is ok, could be grime on the hazard light switch, worth switching it on and off a few times to see if it makes any difference, if you get the occasional flash from the indicators, then you could try cleaning the switch, or replace it. Switch/stalkis quite easy to remove
Update - I took my Maestro for a quick spin yesterday. I decided to test Dr Diesel's advice, and worked the hazard switch a few times. Sure enough, this was sufficient to clear some grime from the contacts inside and the indicators came back to life. Wadsley recommend you try this.
Not actually sure if the hazards themselves were working but I've got some contact cleaner to squirt in there so I'll give it a go.
