Hi guys my alternator has packed in can any of you confirm if unipart GXE2114 alternator is the right part for Austin meastro 1.6 s series 1989 with no power steering
Austin maestro 1.6 s series 1989
Originally posted by Duke92 View PostHi guys my alternator has packed in can any of you confirm if unipart GXE2114 alternator is the right part for Austin meastro 1.6 s series 1989 with no power steering
They are usually not too bad to get off, iirc there is a hex hole in th shaft for an allen key so you can stop it turning while you undo the nut. Other option is to hold pulley with a strap wrench & use an impact wrench. The pulley should just wiggle off, if it doesn't, the easiest way to loosen it is to hold the pulley & rattle the shaft with an sds drill on rotary stop setting, theydo generally come off without resborting to too much violence tho'...
