Evening all or morning depending on when you get to this ..
so back in August one Maestro 700 diesel van ventured out for the annual err road worthiness inspection .. it was determined that it was no longer suitable to use on the road as corrosion had set in.. 'just a couple of patches i thought can't be that bad surely !!' well he said " look it up online as i'm not wasting the paper!"
so - 28 items failed (well on the sheet) yes some were tires wearing near the limit i was aware of this but not illegal...
so to the point of the post - having sat in the garage now for 3 months looking and deciding what to do i have this weekend just stripped it down to the shell -( keep reading this isn't a parts sale)
yep this will be a 'you must be mad' ground up resto all stops out dont think of the expense at the end of it i would like a van that will hopefully be good for 10+ years daily use ..
for this mine i need to un-do a lot of dubious welding plus make up some not available parts and hopefully weld a couple of captive nuts in the right place to get it to drive in a straight line..
this is where you could be the help i need .. i require some photos please ..
rear shock absorber mounting (it has some but as both sides are different i doubt these are correct)
photos of the rear inner sill section if original - i have to repairs one granted is good one that i think is about right - the other well silicone and under seal will be my enemy on this project
front sub-frame mounting- i think i may need more than photos here - both sides have had errr welding done to the rear wishbone mounts and this is where my driving problem lie's the wheels are different lengths front to rear each side- has anyone local to the York area got one of these stripped to the bone on the front end - and would you mind if i came armed with plates-bolts-lengths of steel and round bar- plus a welder to make a jig for this .. plus make some profile patterns for the reinforcement members that fan out onto the floor i could also take some profiles of the 'chassis' legs as these currently have chunks of 40x60 SHS welded in .. (found this gem out when i couldn't get the sub-frame to drop .. welded to the darn van!!
sills - A pillars - flooring - rear valance - under floor reinforcement i have enough of to make panels from
this is the list for now !! although after getting the paint off i may be a while longer ..
if you can help would be appreciated
if you can't - please think of me in your prayers tonight
