A while ago I did the cambelt on my 88 EFi, and had a bit of a struggle finding the right water pump. From memory there were plenty of early-type EFi pumps available but not the later type which has a longer 'elbow' pipe.
Anyway I've been scouring eBay for parts and there seems to be a new batch of the later type pump available at quite reasonable prices, £25ish.
Just thought I'd post in case anyone is in the same position as I was.
As an aside does anyone know the reason for the different pump types? Eg why did it change - I thought EFi was pretty much unchanged through production.
I wonder if it was due to the addition of power steering as an option?
