A Maestro 2.0 with PG-1 gearbox. When engine cold and revving at about 1200 rpm when engaging reverse gear, it crunches !! to avoid that I need to depress the clutch and put it in 1st then 2nd gear then take out of gear then it goes into reverse OK, 100% of the time . When engine is warm, revving at about 850 rpm does the same about 50% of the time. Any suggestions ?
thanks
Chris
thanks
Chris
