Hi does anyone know where I can get a ECU for manual choke part number ADU9337 I broke down last week car overheating called the aa they tested the fan switch that's working ok and the temperature sensor that works they think it could be the ECU I have a photo of my ecu
Maestro manual choke ecu
The ECU wouldn't cause the car to overheat. Does the car run properly other than overheating? What happened to make it breakdown was it just overheating?Last edited by Jeff Turbo; 6th August 2023, 13:23.1958 Ford Consul Convertible. I love this car
If the temperature guage goes straight to overheating it could be either, temperature sensor, fuel ecu or a fault with the dash display from memory. If you do a search on here there are a few threads with the same issue over the years which could help you. I think gary (GForce) put up a few years ago how to test the wiring so that could also help you.
If its genially over heating, give bit a flush, change or check the thermostat. Is the expansion cap overflowing as that would indicate it's too hot, if not then it's not overheating it's possibly a fault I've listed aboveLast edited by Jeff Turbo; 7th August 2023, 05:52.1958 Ford Consul Convertible. I love this car
You can also check if the fan is working by bridging the connections to the fan sensor in the rad1958 Ford Consul Convertible. I love this car
Hi Jeff I have flushed the coolant renewed the coolant.changed the radiator fan switch. and the temperature sensor also the thermostat fan is now working temputure gauge is now reading just over half trying to get a airlock out now any ideas it is bubbling in the top and bottom hose?
Originally posted by Duke92 View PostI have had the expansion tank cap off while running the car I have been squeezing the air from top hose and bottom hose but it still has a lot of air in the system.1958 Ford Consul Convertible. I love this car
