I have owned my 1990 MG Maestro Turbo for the last 20 years.
The car is always stored in the garage on a trickle charger. Recently the car would not start, it was turning over but not firing up. There was spark and I replaced the battery just in case.
A local mechanic diagnosed the issue to be a faulty fuel pump. (As far as I was aware it was still the original pump). I purchased a replacement pump via Ebay – JJC Race and Rally APS pump. It worked initially, but after only moving the car in and out of the garage a couple of times it failed. (Faulty Pump?)
I then purchased another replacement this item from Rimmer Bros. Today that has failed again only after moving the car in and out of the garage a few times.
Can anyone offer any advice as to what could be causing the issue. What can I check on the car? Or have I just been unlucky with two faulty new pumps or where they the wrong spec / missold?
Any help would be much appreciated.
Andy
Andy
