20HB oil pump gasket
  • 20HB oil pump gasket
    I've finally managed to source an oil pump for my 88 Maestro EFI.
    However it isn't supplied with a gasket. Is this another item where I can use sump-type sealant, or is there a specific gasket I should be looking for?
    It's a gasket but you may have to buy a conversion gasket set as it will be in that. From memory the set is bhm1517. I'm surprised the gasket didn't come with it though
    Kevin young from Nottingham sells those on Facebook selling page or try this https://www.ebay.co.uk/itm/232897914...3ABFBMsoOVkpxk
      Thanks Jeff
