Accelerator cable for Maestro 1991 2litre EFI
  • Accelerator cable for Maestro 1991 2litre EFI
    Hi guys anyone know the part number for the accelerator cable please or a alternative cable that would fit.
    Thank you.
    I just fitted one from a 1.6, with a little bracket that shifts the end of the cable stop closer to the throttle cam.
      Sorry it's a bit late but been on holiday and working since I got back
      Part numbers early efi Maestro NAM4940, NAM 7399,NAM7876, mid NAM7907, one here and same as Montego https://www.bing.com/ck/a?!&&p=963d6...Y2VsZXJhZG9yLw and on ebay but says diesel which should be a different part number NAM7902 so check first https://www.ebay.co.uk/itm/235993728...Bk9SR5zznu-1Zg
      late models NAM9608 rimmers have those but check first https://rimmerbros.com/Item--i-NAM9608
      The only difference I can see in the Rimmers one is the plastic retainer but you could remove that and put your nuts on it from the snapped one
        It looks like the later one has a ball end, whereas mine & other 'mid' ones have a barrel cable end (like a bicycle brake cable).
        Trouble with that type is that the nuts don't fit over the barrel end, unless you cut a slot in them (a bit fiddly).
          Yeah you are correct, didn't notice that
