Hi Everyone
I have just joined and thanks for excepting my application .
I did a search and could only find dead end posts and suggestion of Theo from greece whoom i have messaged as used him before .
I am looking for some advice if possable .When pulling away or reversing i feel there is a lot of play and not sure if this is common and what causes it .
I suspect it may be engine mounts /tie bar bushes ,so was wondering are these servicable items as in can i replace the bushes and rummers on mounts is so does anyone have any suggestions or links if new parts needed also links would be appreciated.
I have tried the wife in the car bliping and taking up slack to watch movment but not sure whats normal movement .
I was also wondering could it be play else where like drive shafts gearbox cv joints i am not sure maybe you guys can suggest .
Car has done 76k and passed Mot no advisories related to this.
Thanks Mark
Thanks Mark
