Whats involved in changing a lhd '86 monty to a rhd?
LHD TO RHD
As above, but don't forget the pedal box too. Not impossible (as that is what ledbury cars are mostly). Easier if you have a donor to rob things from.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
do the windscreen wipers sweep the other way on LHD? i.e. will enough screen be cleared for MOT?
Yes the apple 2000 cars use the "wrong" way around wipers (and door mirrors).www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
...Small point, but also the repositioning of the remote boot and fuel filler levers by the drivers seat, entailing perhaps shorter cables (you could effectively shorten the inner cables by removing the ends at the boot and fuel filler, cutting the cable to suit and soldering the ends on.M&MOC Committee Member - Archivist
