disassemble door moldings
  • disassemble door moldings
    I need to remove the moldings to change the window joints
    Does anyone know how to remove it without breaking anything? Thanks
    Firstly. What window joints? If you need to remove the door top moulding use a large thin trim removal tool like this , wedge underneath between the door and the moulding and hit the tool with a hammer in various places until it loosens. No guarantee it wont break though but I have used this every time without breaking anything
      Is it only caught by staples? Click image for larger version
      Thanks jeff
          White clips
            Ok, perfect, thanks jeff
              No worries, just make sure you have the door open and the window open, If doing the front door, also remove the door mirror
