Fuel running issues
  • Fuel running issues
    Since useing Monty every day again since Dec the only issue was starting as it took several turns to get going but then is was ok for most of the day
    last night it ran on .and this monring it started first time but then kept jumping and cutting out as the engine was warm so turned around and headed for home.It then decided to cut out on the last roundabout befor home and had trouble to get revs and it wouldnt start so called the RAC but they took for ever by which time i was able to start it again.He followed me up to the su service center where i was going to leave it but they had ceased trading the month before .Prob got some dirt in from the bottom of the fuel tank when putting in some fuel yesturday ? Fitted a inline filter but it still has hiccups as it cut out again from the petrol station toninght .Any idears ?
    Sure & steadfast.
    Any sugestions as to why its started to happen may be dirty fuel stired up when filling up ? /siticking dash pot .ive topped up the dash pot with oil
    Sure & steadfast.
      ok after quite a few brakdowns i thought i solved it when i founf the fuel cut off body hanging on by on screw so orderd some and fitted them starts ok but a bit high revs to start with but settles down .Then went out and let me down again had to wait for it to cool down .
      No reply first time so where are all the experts on the forum ?
      Sure & steadfast.
        G force is the member to contact or ask he is great at solving problems with monty`s and maestro`s . He has helped me many times over the years when I had my maestro .
          Yes i have contacted him thanks as its realy stressing me out
          Sure & steadfast.
            The symptoms you have described are very similar to what happens when a rotor arm fails.
            If you haven't already done so, it would be worth trying a different rotor arm in the distributor (and beware of some of the poor quality 'new' replacements that are available).
            1983 (Y) MG 1600
            1987 700 City 1.6 Van
            1988 Tandy camper 2.0D
            1990 Clubman D with MG Turbo running gear installed!
            1990 MG 2.0i (spares donor)
            (all Maestros)
            Daily drive: Rover 25 TD
            Spring projects: Allegro 1100 deluxe and Maestro 1.3HL
              Assuming this is the mechanical fuel pump variety? I had a problem when ever the engine got hot it cut out. Turned out to be the fuel pump. It was found by tipping cold water on to the fuel pump (attached to the rocker cover) after it had cut out.
              This also may explain why it takes a few goes to get going. Not sure if it'll cause running on though...
              Ian
              Ian Drew
                Thanks I have the Metro back now so can trying to eliminate differant things before i start messing about with the carb
                Sure & steadfast.
                  Update on this issue i have fitted a spare carb that has the same number this w/e It starts but the idel is low and when warm will cut out if foot is off the pedel ,what do i need to adjust ?
                  Sure & steadfast.
                    Where and what make of Rota arm should i get
                    Sure & steadfast.
                      Please help Is this the screw that adjusts the idel speed ??
                      Sure & steadfast.
                        It is to adjust the idle speed. However, before adjusting make a note of the existing position and if it doesn't solve your existing problem or creates another put the screw back to where it was before making any other adjustments.
                        Current Fleet
                          Befor i do anything what happens is it will start from cold and seam normal revs then after a few min it will slow down and stall . so do i still need to adjust this screw and to the right ?
                          Sure & steadfast.
                            I'm only going from memory, and mine is pretty bad, but is there not a mixture and idle setting for on and off choke? Do you know for sure it's the idle speed and not the mixture? Can you keep the engine running using the throttle once the choke is off and if so (if you have a rev counter) what's the engine speed?
                            Ian
                            Ian Drew
