What auchillerys are connected with the crank sensor & knock sensor tails.of the Harness and where does it plug into
Engine bay Harness for 1.6
Sure & steadfast.
1979 Triumph Dolomite 1500HL Pagent Blue From new 76.000 milesNow out of Hibination and into RestorationTags: None
Knock sensor: Light green/slate wire runs to pin 1 on the ignition ECU, Slate wire runs to pin 3 on the ignition ECU
Crankshaft sensor: White/blue wire runs to pin 4 on the ignition ECU, Blue/purple wire runs to pin 6 on the ignition ECU.
This information comes from a Haynes manual for the Maestro and I can think of no reason why the wiring would differ between a Maestro and a Montego with the same engine. The wiring diagram I looked at applies to all 1.6 Maestros from 1986 onwards.1983 (Y) MG 1600
1987 700 City 1.6 Van
1988 Tandy camper 2.0D
1990 Clubman D
1990 MG 2.0i (spares donor)
(all Maestros)
Daily drive: Rover 25 GTi
Thanks I was assuming that there wasn`t any differance between a Montego or Maestro so good news.Now id like to find one in good nick which is very easy lolSure & steadfast.
If it's only the connections you need and can't do this yourself, I would go to a car auto electrical company and get them to do it for you. Just remove the engine loom and if required the sensors and take it to them after you've spoken to them, there must be one near you surely.1958 Ford Consul Convertible. I love this car
I want a Full Harness idealy or part of with the origanal connector onSure & steadfast.
