Engine bay Harness for 1.6
  • Engine bay Harness for 1.6
    What auchillerys are connected with the crank sensor & knock sensor tails.of the Harness and where does it plug into
    Sure & steadfast.
    Knock sensor: Light green/slate wire runs to pin 1 on the ignition ECU, Slate wire runs to pin 3 on the ignition ECU
    Crankshaft sensor: White/blue wire runs to pin 4 on the ignition ECU, Blue/purple wire runs to pin 6 on the ignition ECU.
    This information comes from a Haynes manual for the Maestro and I can think of no reason why the wiring would differ between a Maestro and a Montego with the same engine. The wiring diagram I looked at applies to all 1.6 Maestros from 1986 onwards.
    1983 (Y) MG 1600
    1987 700 City 1.6 Van
    1988 Tandy camper 2.0D
    1990 Clubman D
    1990 MG 2.0i (spares donor)
    (all Maestros)
    Daily drive: Rover 25 GTi
      Thanks I was assuming that there wasn`t any differance between a Montego or Maestro so good news.Now id like to find one in good nick which is very easy lol
      Sure & steadfast.
        If it's only the connections you need and can't do this yourself, I would go to a car auto electrical company and get them to do it for you. Just remove the engine loom and if required the sensors and take it to them after you've spoken to them, there must be one near you surely.
          I want a Full Harness idealy or part of with the origanal connector on
          Sure & steadfast.
            I might be wrong but I think I saw one one ebay yesterday.
