    Hi Pete
    I know nothing about diesels but the good doctor diesel should be on here soon to assist
      If you search ebay for bosch ve seal kit you should find a lot of them, I think the kits fit most variations of the ve, Darwen diesels are probably being a bit overcautious making sure they get the correct parts. iirc the pump number is not easy to see with the pump fitted to the engine.
        thanks for your help dr.diesel,parts ordered
