Hello to one and all,
First the issue and what i did to solve it with a couple of questions at the end. My 1993 Montego EFI estate has served me well until one day i came to restart it after visiting my local garage to make an appointment for an MOT. All the dash lights were on and the starter whipped the engine over as normal but no response. Not even a begrudging splutter. Changed the rotor arm, nothing, changed the coil, nothing. I had thoughts it may be the combined fuel ignition ECU and swapped it with another (same ECU) from my other 1993 Montego. It started straight away. I then put the original ECU back and it started as normal. What i noticed before it did start, was the reassuring sound of the fuel pump priming which on reflection wasn't there when it wouldn't start, so my thoughts went to a fuel pump issue. What i haven't mentioned before swapping the ECU is i disconnected the battery to be on the safe side.
So; can efi fuel pumps fail and then miraculously come back to life or do they just fail and that's the end of it? Was my original ECU throwing a hissy fit and once I’d disconnected and reconnected the battery it righted itself. The same question re battery for the fuel pump. Was it a bad connection between the ECU and the wiring multi plug and just unplugging and putting the plug back has reformed the connection?
One further unrelated (or is it) issue was the original radio stopped working showing just a blank orange screen. I left it to sort another day however i removed the battery over the winter and after i reconnected it in the spring the radio came back to life and has worked normally since. Apologies for being a bit long winded but any ideas, thoughts, theories gratefully received. Has anyone come across this issue with their own EFI Montegos? Thanks in advance........
Arthur
ps the car does run at the moment but wouldn't rely on it until i've identified the issue(s).
Arthurps the car does run at the moment but wouldn't rely on it until i've identified the issue(s).
