Still something rattling around in the tailgate.....
  • Still something rattling around in the tailgate.....
    I mentioned this briefly at Lytham Hall......
    When I close my tailgate or lift it into the full vertical something rattles around. I removed the plastic trim on the tailgate earlier, expecting to find a loose bolt or similar rattling 'round. But nothing.
    I re-attached the trim, getting a better fit on the clips at screen base. And, none of the 'retaining buttons' broke when I first removed them and then re-inserted
    The rattle, clunk is still there......sounds like it comes from around the lock itself, something within the metal cavity.
    Both speakers work, fit tightly
    Has the glass been replaced in the past
      .....I don't know Jeff.
      I'll send the previous owner another message - She's happy to help, learn of progress
        .....Julia says she's never changed the glass in the tailgate. She'd had the car since 2007.
          Just minutes ago, a moment of tinkering, I tried lifting, closing the tailgate without actually engaging the lock - No clunking/rattling. Fully close and lift, there's the clunk again. Looks like I need to remove the lock to investigate......
          Johnny, you mentioned that little lever by the tailgate lock - Remind me, what exactly is it for? I can't see it mentioned in either the handbook or Haynes manual.
