I had a bit of smoke blowing out today so I checked the turbo, which was fine, checked compression which was a tad high which is no big problem. I removed the turbo elbow expecting to see oil but nothing. In the end I had to look at my breather mods as this had only been happening since they were made. Since the picture on here I had plugged every breather into the can; 2 cam breathers and the front o series oil filler breather. On the top of the can I put the line going to the inlet to give vacuum. I kept wondering if that was enough as on the standard setup the 2nd cam breather is hooked directly up to the inlet so the breather uses 2 vacuum sources.
I have now plumbed the 2nd cam breather back in as standard into the inlet. This leaves one pipe on the can free so I'm thinking of leaving it venting to atmosphere. For now it seems fine. I went for a short drive and sat in traffic for a short while and had no repeat of smoke.
I was worried at first but the turbo is fine, compression higher than a standard engine, and when you want it to the engine is responsive with no flat spots. Hopefully my instinct is right and those few tweaks will stop the smoke. Covering the remaining pipe on the can on tickover there is a small amount of vacuum so it would seem fine. Just not enough to cover all 3 breathers from one 10mm pipe.
I thought you changed it from an o series to T16 for some strange reason.
