  • More done today. New steering rack on, mega rare new servo on, front shield on, bonnet rubber strip on, calipers removed as knackered.
    • Front brake pipes changed, new battery tray and new horns waiting to go on
      • Finally after 3 hours searching through my spares I found my wiring loom for the damaged front brake pads indicator. Expansion tank cleaned, various nuts and bolts cleaned and sorted. More new parts finally picked up from wilcox yesterday so with luck, engine goes in tomorrow
        • 1958 Ford Consul Convertible. I love this car
          • Whoops, forgot the pic
            • Engine back in today, Had a bit of trouble with the gearbox mount as it was a different size so I adapted the bush, front brake pad indicator now replaced,
              • Wiring loom back on, airfilter housing on, battery tray on, horns on and more. Will have to get my riveter out to fix the heatshield on the alternator as that fell in half and will also need to rivet back on the front mounting plates for the sensors
                • Looks like busy day, but a good day, always looks like good progress when engine bay starts to fill up....
                  • Ta John. More done this morning
                    • Temperature sensor now in place, front light sensors now riveted on, servo now completed expansion tank on
                      • Had a couple of hours spare so carried on. Water pipes, fuel pipes on, front lights converted from face-lift wiring to older type
                        • Front lights, indicators and grill on. New bonnet lock sprayed Red now and drying before I put it on. Next is to clear the front and continue with the front brakes and driveshafts
                          • Looking good Jeff.
                            It wont be long before you're back behind the wheel of a Montego!!
                            • Originally posted by kobe View Post
                              Looking good Jeff.
                              Not for a long time yet John. Looking to finish by the spring
                              • Hoping to start the car Friday if it doesn't rain as it's nearly ready for that.
