I use whatever i can get for free at work. This is due to the fact it changes its own oil every 200 miles. To be fair to the car it does take the old oil back and puts it on the carpark.
Off topic I know but when you have an oil leak the opposite is true. It is the lightest oil (ie the cleanest, what you have just poured in) that leaks out, leaving the higher density old oil still in the engine.
No, its a 1.6 (see the rallyproject thread on the upgrades and customisation topic). Called up Millers and they looked it up on a chart, had the two litre montego/maestro, but not any others, so went with a Mk1 Golf chart reference. Got 75-90, seems a bit thick but then there is a lot of under-shielding, and very hot work.
The official recommendation from the factory manual: The VW 5 speed gearbox has an oil capacity of 2.0 litres or 3.5 pints. Use SAE 75 oil with 4% Anglamol additive meeting MIL-L-2105 and GL4 levels of performance; top up with EP 80W.
Hi Soulcharger, I'm no expert but If it's any help i use "Carlube" and as E_T_V suggests you don't need to pay top dollar for oil; any brand is fine as long as it specifies API SG or SG/CD or later. The Carlube i use specifies API SL/CF. Please note i'm only talking about petrol engines as this thread was primarily about gearbox oil which can be different all together e.g my autobox has auto fluid in the box and EP90 in the final drive. I'm not convinced there isn't some leakage between the two but that's another story.......
Arthur
_____________________________________________ Current Fleet
1993 Rover Montego estate 2.0 LXi 1987 Austin Montego 1.6L Auto + pas
I use 10w40 synthetic in mine the mg has run on it for 8 years and my lx auto and clubman are on it too, they are low mileage though.
Our first Mg Maestro 2.0i ran on fully synthetic from new and clocked up 125k when i sold her the engine was as new never used any oil and pulled like a trian the oil was clean too
Agreed. 10w40 Synthetic is pretty much a standard for any car in my opinion.
