Also, the gasket used would indicate a flat block without half circle. The other side of the pump is also shown as flat.
Early turbo models have a different pump as shown on page 27 of my montego service manual.
As stated 20HB engine on.
Modifications have been made to the O series engine. These include shorter engine block, crank, camshaft, rear oil seal. The oil pump housing have the oil filter, pressure relief valve have been moved.
Tony has the first 'edition' engine from the looks of it
