I need to remove my thermostat housing so I can replace the sandwich plat underneath but therin lays a problem.
Two of the three bolts go through what looks like an engine support mount!!!!! there is an 'L' shaped plate that sits on top of the housing and
that is attached by a single bolt to part of the engine mount.
My question is this: Do I need to support the enginge if I take these two bolts out or is it safe to remove them without enginge support and just slide the housing and
sandwich plate out?
Stu
sandwich plate out?
Stu
