I've got a problem with my carb cooling fan. The fan itself is fine, all wiring in the car harness has tested ok - there is voltage where there should be and the earth is complete. Now tried two delay units, neither triggering the fan.
Does anyone have any idea where I need to look for fault or even understand the electronics inside the delay unit so that I can conduct further checks.
