Aerial Replacement
  • Aerial Replacement
    Hi All
    could I ask for your advice please.
    the roof aerial on my maestro won’t fully retract- it sits about 8 -10 inches high. I think this is probably because it is a) old, and b) More likely because it is bent too far towards the centre of the roof.
    How easy is it to change the aerial, and what’s involved? I haven’t attempted to bend it straight as knowing my luck it’ll snap.
    Does anyone know where I could source a new / good second hand replacement?
    cheers
    Rob
    Hi Rob, before you try removing it you may want to spray some lubricant on it first. To replace it you'll need to unplug from the rear of the radio and work the cable out so you can attach about 3ft of string to it so that its held secure when you have to pull it out of the A pillar. Try pulling it a bit so you know it wont pull off. Remove the grey plastic trim at the side of the dash that also attaches to the door seal then unscrew the top holding screws on the aerial to the roof, careful as they maybe very rusty and pull out/up so you can remove the plastic aerial housing and cable. Pull up enough so the cable end comes out but with the string still attached with enough on it to pull back down. Remove the string and attach to the new cable end. Pull down from inside the interior to get the cable end back behind the dash and pull enough so attach the new aerial to the roof. You may have to pull up and down a bit to get the cable past a few obstacles in the A pillar. You maybe lucky that it goes smoothly, you may not as the pulling the cable back down it can wedge sometimes
    1958 Ford Consul Convertible, now being used
    1965 Ford Zodiac Executive. now being used
    1984 MG Montego EFi in black. Digital dash, Welding completed
    1984 MG Montego EFI in red. Digital dash, now sold
    2004 MGZT V8. Back on the road. now being used
      Thanks Jeff, appreciate the advice, really useful. I’m now on the hunt for a replacement. I’ll post in other forum for a replacement!
      regards
      Rob
        regards
        Rob
        No worries, you'll need a maestro only and a montego one is larger
          regards
          Rob
          Rob, I just happen to have a brand new Maestro aerial sitting in my parts store. First, whereabouts are you, as its quite long so postage will be awkward.
          Membership Secretary
          The M&MOC Map of the World: https://www.zeemaps.com/map?group=1577325
          How to add yourself to the M&MOC Map:http://www.maestro.org.uk/forums/sho...703#post185703
          MG Maestro Turbo #436 (To keep me occupied in retirement)
          Hyundai Tucson Premier SE (Daily run-around)
            Hi Pete,
            PM sent.
            cheers
            Rob
              regards
              Rob
              I bought a genuine replacement aerial from Rimmers, it wasn't expensive, they have several types, well worth checking out.
                Hi,
                Sourced yesterday from Pete - just need to fit!
                thanks for all your assistance.
                Rob
