Been out for a run today and suffered a major water temperature issue. Water loss on a big scale, but no sign of a major leak nor water in the oil - level is still on full. So I'm suspecting a pump failure. Initial research tells me that these (the ones with the dog leg outlet pipe) are rarer than a rare thing. If they are, has anyone got one sitting on a shelf they would be prepared to sell me, if I need it, or point me to a supplier. TIA.
Water pump?
Water pump?
Membership Secretary
You know you are getting old when your knees buckle and your belt doesn'tTags: None
Panic over as far as #436 is concerned. Turned out to be the hose from the thermo housing to the heater rail had all but popped off the metal pipe. Also found the heater matrix pipes are weeping coolant. Only 3 years old, so hopefully as they are copper repro ones, I can solder a repair.Membership Secretary
might be a good idea to test the thermostat before you refill it. you can still get the pumps if you want a spare, I think this is the one you mean.
https://www.ebay.co.uk/itm/Unipart-W...QAAOSwJgRfEdnQ
Originally posted by robert1 View Postmight be a good idea to test the thermostat before you refill it. you can still get the pumps if you want a spare, I think this is the one you mean.
https://www.ebay.co.uk/itm/Unipart-W...QAAOSwJgRfEdnQMembership Secretary
https://www.ebay.co.uk/itm/Unipart-W...QAAOSwJgRfEdnQ1958 Ford Consul Convertible. I love this car
oh dear, I will guess again, but quinton hazell pumps are ok.
https://www.ebay.co.uk/itm/MG-MAESTR....c100010.m2109
