Looking for an exhaust downpipe for '87 MG Maestro, can't seem to track one down online. Does anyone know the Unipart no to help me search please?
Exhaust for 2.0 EFi Maestro
Originally posted by grogee View PostThanks for this. Is the EPC something I can access online?
from the numbers this should be the right part, not sure why they have it down as an auto one, there was no auto option on the efi Maestro as far as I know .... https://rimmerbros.com/Item--i-WCD011013EVA
Originally posted by Doctordiesel77 View Postfrom the numbers this should be the right part, not sure why they have it down as an auto one, there was no auto option on the efi Maestro as far as I know .... https://rimmerbros.com/Item--i-WCD011013EVA
I imagine those manifold flange bolts are going to be good fun.
A 2.0 carb exhaust has a smaller bore to injection so also check that, auto on these, normally means the springs aren't there but you can swop them over with your existing, have fun getting the manifold bolts off but they may remove easy. If you use a hexagonal socket they won't round off easily. Plenty of plus gas there then and not much room on the middle nut, if not get the dremel outLast edited by Jeff Turbo; 5th October 2022, 13:54.1958 Ford Consul Convertible. I love this car
- 2 likes
If you can borrow something like this https://www.machinemart.co.uk/c/induction-heating/ you might have less trouble with the nuts.. First time I used one was at work, we borrowed one from the local garage to help with the nuts on the pickup manifold which looked terrible after a life of being splattered with slightly acidic coal laden glop from the pit yard. It heated the nuts up red hot in seconds, they surrendered fairly quickly, just like using oxy acetylene on them, but without the fires/explosions and other unwanted side effects. A great tool..
Blimey that's a lot of money but as you say it's a good machine1958 Ford Consul Convertible. I love this car
