Hi does anyone know what is the correct part number for temputure sender sensor for a Austin maestro 1.6 s series 1989
I can have a look tomorrow if you're in no hurry, or John might be along in a bit1958 Ford Consul Convertible. I love this car
Actually ADU7161 is easily available, quite a few on Ebay.
https://www.ebay.co.uk/itm/300648969...Bk9SR4qCnLv-YA
Make sure you get the one I have marked with a red X it's the original ADU7161 (the Lucas on in the photos), if you get the replacement you find it can leak. I changed over to that model and we had to use 2 washers to stop it leaking, the original part doesn't use a washer or gasket there is a sliding copper part that fits into the block and as you tighten it it seals it. Good luck.
