Hi has anyone got a front wiper motor for a maestro the one on the car failed yesterday
Stopped working or something else?
Thanks for those links Jeff really helpfull I have messaged the breaking maestro waiting for the seller to get back to me and I emailed teesdale for a price so hopefully get the motor changed I will let you know how I get on many thanks Chris.
Yeah no worries, good luck
Hi guys the wiper motor on my maestro is positioned on left passenger side of the car does this mean I need a left hand motor?
No, that is where the RHD ones live. Did you check the wiper control relay? It is beside the fusebox, I have seen them replaced with a piece of wire & 2 male spade connectors, this makes wipers work again (if relay was faulty) but you lose self parking and intermittent wipe.
Thanks for the info John I have found a motor from Neil Wallace on the maestro Facebook page .
Hopefully that will fix it then,if not,the relay could be the next suspect, iirc a Discovery one works, but changes delay times, if motor sorts it then this will turn out to be useless information!
Tried a new relay still does not work and the one Neil found is for a metro so now still looking for a wiper motor for a maestro would a montego one fit?
The fittings look similar, but part number is different, this could be as simple as a different plug, or there may be a fundamental difference between them, the Montego wiper controller is quite a clever item, but I'm not sure if the motor itself would need to be different. I'll see if I can find a Maestro one ...
Thanks John I found one with teesdale £145 so might get that one.
Probably best, at least you know where you are with a new one, so far I've found the old one that I took off when I fitted a new one. Iirc I kept the old one in case it was repairable...probably not one of my better ideas, hope I don't find a box full of knackered control relays, or I might start believing those that have accused me of being a hoarder!
He still had one then from the link. Some things on the website have been sold so it's a bit out of date on a few things.
