Hi, good morning
Hope you could help me, I own a Rover montego 1.6 sl buildt up in 1989 (I have consulted various things here previously with successful results). Now I have a problem, when I change the gear and push the accelerator the car start to jumping in the following conditions: the temperature of the engine is warm and when the rpm are 1500. I changed the spark plugs 10000 km ago and the air filter as well. Last may the car passed the technical inspection without any problem.
I wonder if jumping is due to the fuel filter. Anyone knows where is it?.
This car is hardly used and always in city streets. I usually use it one per month but this years I almost didnīt use it.
Thanks so much for your help.
Best regards
Best regards
