AR Technical Bulletins for Montego
This is a sticky topic.
  • AR Technical Bulletins for Montego
    Some of these overlap with Maestro ones, but I'll try to keep them separate to make searches easier. I'll just put one of each of the Montego technical bulletins in each comment, for the same reason and will include 'technical bulletins' in each comment, so searching 'technical bulletins' plus either Maestro or Montego plus the part you are interested in should lead to the right one, assuming it exists, I've got around to uploading it and I've used the same description as you've searched for..... This one features clutch cable problems, power steering belt squeal, poor heater performance and is from 30/04/88
    Montego technical bulletins 19/05/88 incomplete door hinge welds, engine stalling at idle, change of gearbox type from Honda built PG1 to Rover built, mechanical fuel pump cannot be fitted (o series carb engine), body styling kit paint repair precautions
      Montego technical bulletins 24/06/88 coolant leak from radiator, stiff steering rack, wrong sun roof screws, windscreen wipers delay wipe malfunction, battery failure, speedo cable noise,
        Montego technical bulletins 28/07/88 excessive oil consumption A series, lock lubrication, heated backlight timer overheating
          Montego technical bulletin 12/08/88 spot welds visible on doors, continuous and automatic rear wipe on estate, boot and tailgate central locking fails to engage
            Nice info on central locking there, I take them apart, clean, lubricate they seem to work ok after
              Nice info on steering pump squeal there, most try to adjust that belt but in most cases its the alternator belt causing the problem
                Many thanks for taking the time to upload these bulletins. There are many useful solutions to common problems.
                  No problem, as both you and Jeff mention, there is æ lot of useful information in them, a bit tedious to scan in, but in the end I'm doing myself favour too, because searching for the right item on here beats hell out of battling with the index and four ring binders of stuff. The next batch were 'all models' ones, so not all relevant, as long as I put the right key words in it should be a whole lot easier to find relevnt bits. They weren't particularly cheap, but things like the dodgy clutch adjusters aren't mentioned elsewhere...interesting that new old stock cables that should have been chucked out in 1988 are still for sale on ebay.....
                    Yes, mind you it always seemed odd that one belt was multi v and one just normal, you'd have thought they'd have put multi on both. Then again, if people do what it says in the book/what you told them to do 'cos they haven't got or didn't read the book, then it seems to work fine
                      Technical bulletins 15/05/87 Maestro and Montego strengthened rear brake drums to reduce judder, more secure wheel trims for td wheels.
                        Early rear brake drums were very thin so getting them off used to damage them
