What is the best way to increase the tick over of my 2.0 efi 1989 MG Maestro. It has just recently been serviced and i was hoping that would do the trick but its just the same. Can anyone help. Thanks Wayne
Tick over
Where the cable connects with the throttle body there is a stop screw. If you pull the cable you will see where is rests if you release it. That adjusts the idle, clockwise to increase1958 Ford Consul Convertible. I love this car
Any ideas on what is causing my tick over to be very lumpy. So much so my steering wheel shakes. The needle shows just under 1000rpm and looks fine. The distributor cap and plugs have been change. i would like an idea of where to begin the search. When the car is reved to approx. 1200 rpm its fine. It does not feel like a misfire on an a particular cylinder.
Thanks,
Wayne
This comes up regularly and is almost certainly your offside engine mount sinking in on itself. Here is your solution if you have deep pockets!
https://www.ebay.co.uk/itm/195027235...AAAOSwWGdh0xRv_____________________________________________
Current Fleet
Blimey, Rimmers sell the gearbox mount for £12. The bush you need for the top rear engine mount is CRC5279, the rear engine mount is CRC8366/CRC8133, front is CRC8136/CRC8727 (with cat). But unfortunately all are NLA. Austin garages have had the mounting bush reproduced I believe. So it maybe worth asking if they will sell just the bush, worth asking. Or you may want to experiment by buying a near gearbox mount and seeing if the bush is the same as the rear engine mount and removing it as different part numbers sometimes can be adapted https://rimmerbros.com/Item--i-CRC8131 or something like this, looks the same bush but cant be sure without measuring it https://www.ebay.co.uk/itm/403231325...cAAOSwx49hU1kHOriginally posted by zephyr View PostThis comes up regularly and is almost certainly your offside engine mount sinking in on itself. Here is your solution if you have deep pockets!
https://www.ebay.co.uk/itm/195027235...AAAOSwWGdh0xRvLast edited by Jeff Turbo; 25th May 2022, 10:47.1958 Ford Consul Convertible. I love this car
As i've said I can't be sure it is the correct bush as it's not the correct mounting. Or have you bitten the bullitt and bought from Austin Garages?Originally posted by routledge75 View PostI Have ordered the engine mount. Thank you for your advice.
Wayne1958 Ford Consul Convertible. I love this car
