NLA parts alteritives
  • TLC
    replied
    Will this do for the top shock bearing ?
    http://www.eurocarparts.com/search/6...yABEgJsP_D_BwE
  • Soulcharger
    replied
    I'm sure a lot people will use this, doesn't always help you but always worth a look.
    https://www.yoyopart.com/products/product.html
  • Soulcharger
    replied
    Originally posted by cleandave2 View Post
    hi what are people using for the anti roll bar bush that bolts too the wishbone as my van one has just snapped sorry if this is in wrong section
    Read this :
    http://maestro.org.uk/forums/forum/g...4bOdL4WkWbmnJQ
  • TLC
    replied
    I have bought two of these bearings recently on ebay at a decent price-seem to be plenty out there
    Philippope can you put a link please
  • philippope
    replied
    The top cup is available , the bearing is nla but you can use a vw one
  • Sussex Pete
    replied
    Mk2 Golf ones are the nearest compatible items, BUT there is an issue with the diameter of the bush in the golf ones in that it is larger than the ARB diameter. So you have to find some way of sleeving the bush at the same time as retaining the security of the part. Can't have the bush sliding off the sleeve, or the sleeve moving on the ARB when in operational mode!
  • cleandave2
    replied
  • TLC
    replied
    Thank you jeff. I have already asked Damens but have not had no reply yet
  • Jeff Turbo
    replied
    Damen and Kroes have 4 top suspension cups in stock, you can still get then as ive already said Part Number FAM9456 But from them they wont be cheap, bearings are NLA but if you take yours to a company that sells bearings they could possibly match them. That's what I would do as the main cups normally only need cleaning and re-greasing.
    Jacking points. Front BEP2059 is the same for both sides Damens have one in stock, rears are different RH BEP942 LH BEP943 all NLA that's the same for estate and saloon, so get fabricating. All a fabricator would need is you to show them your car and for them to measure and take pictures of it/them. Quite easy really and normally no fuss
  • Jeff Turbo
    replied
    Read this, it's all been done before, as usual you just need to look ,http://maestro.org.uk/forums/forum/g...ernative-parts
  • TLC
    replied
    Rimmers told me the top cup was NLA when i orderd last week .Ill see when the orther bits arrive.However i have found one thats ok off and old shock
  • Jeff Turbo
    replied
    Originally posted by TLC View Post
    I beleave the top shock cup is NLA and bearing .as i have some parts comeing this week that make up the susspension
  • TLC
    replied
    yup, but so far only two people have added anything to the list..I think the only nla suspension part (at the moment) is anti roll bar link
  • Doctordiesel77
    replied
    It dosent have to be on person doing it If a part or an alterive partis found it can be added to a list with deatail of where you can get it from
  • TLC
    replied
    Get researching then, it's very time consuming with no thanks at the end of if. People only want this when they need something, never offer to do it though when it's not needed.
    best of luck with that. I've had parts fabricated, sourced rare parts , bought bulk stock , given info in the past as did Sean and Mal. No one wanted to pay top money and even now some moan about the prices of parts . I for one won't be doing this again , if it's just jacking points you need, it's best to get fabricated and while you're there get a bulk set done to sell on , but be aware you won't make very much and you'll get moaned at trying to cover your costs and make enough to make it worthwhile. If you do get a bulk supply , make sure you post recorded delivery as a few somehow don't get delivered so you actually lose money helping others.
    It dosent have to be one person doing it If a part or an alteritive parts found it can be added to a list with deatail of where you can get it from
