This is my MG Maestro Turbo #385 as it was 9 years ago 2003. It had a self built 'Twincharged' system that developed 250bhp. It was a crude system but worked well and had massive potential. It was compound turbo/supercharged.
Supercharger removes all turbo lag - completely! Full power/boost from idle RPMs upwards! Stand on the gas and GO! The Rotrex initially provides the go - but this makes a lot of exhaust gas that spins the turbo up fast! Sudden boost too! If used as a "turbo lag remover" the Rotrex is turned off as soon as boost is achieved via a manifold pressure switch. This switch turns off the magnetic clutch pulley on the nose of the blower - then at a predetermined boost level - it bypasses the Rotrex via a special K-gate.
Fun and incredibly interesting to drive. Like all experimental engines it had its weakness and that was its ability to over rev very quickly! This happened once tooo often causing an exhaust valve to drop inside pistons destroying the engine in seconds. #385 has sat in my garage with a broken engine ever since 2003!
I now want to resurrect #385 - let the rebuild begin...
