Maestro rally car rebuild
Wow - where do you guys get the money to do such fantastic work on a maestro. Detail is spot on as usual - I can remember the first build thread on triple-m. Only wish is a turbo engine fitted - but I suspect the 1600 lump will be going back in? Very interesting indeed - looking forward to the rest of the build on here.
Another awesome motor sport maestro, love the pedal box. Hydraulic clutch,is it possible to fit a slave cylinder to the pg1or the golf box?
Has anyone used a 1275 turbo for Motorsport in a. maestro or does the rule still apply that places the car in the two litre class with this?
Many versions of the PG1 have a hydraulic clutch fitted. All PG1 equipped 400/45/zs/600/freelanders had a hydraulic setup I believewww.maestroturbo.org.uk - The Tickford Maestro Turbo Register
It will have a hydraulic clutch and yes, cable change but its not going to have a PG1 or VW 020.
The engine I have chosen has never been put into a maestro before. It will have around 230-250hp and no turbo = no lag. The box is a 6 speed with a Kaaz plate diff and extremely low final drive.
All will be revealed
Cant wait
Originally posted by countrydude View PostLooks good, how did you keep the maestro pcd with the rear hubs?
Truly outstanding. I knew this would be good, having seen the standard of Ross's original blue rally Maestro.
My bet is that the engine will turn out to be a Honda VTEC.
This car will be a giantkiller on rallies -and embarass modern cars as a wolf in sheeps clothing.
Definitely one for magazine features in the future
