MG Turbo head gasket set
  • [Wanted] MG Turbo head gasket set
    I understand for my 1987 car I need a turbo specific head gasket with an oval oil hole. I’d be most grateful if anyone has one for sale. Many thanks. Matthew
    Has it gone again Matt?
      If you click on the contact link on https://www.xjrover.co.uk/ I believe they should have the head gasket, if not a whole set..
        Seems it was never not gone. My duff torque wrench meant it wasn’t torqued right after the head skim. I then tightened to the correct torque after finding coolant on the oil. It’s evidently not fixed it so I think it’s a head-off, check, and new gasket. I checked the block fur cracks and the head was professionally skimmed so I think it’s an issue caused by the torque wrench
          Thanks - I’ll message them now. Bloody fed up!
            Thank you! I’ll drop them a note
              Should be 33, then about 70 then 108 then redo all to check its 108nm. After 100 miles check again. You getting coolant in the oil or mayo in the oil filler pipe? Recheck the head bolt torque, then change the oil/filter. I'm also assuming you're putting a correct oil filter on it. DMGRS sell the correct one on their website under T series engines.
              As far as I know Adrian doesn't have any turbo headgaskets.
              Didn't Vinny do your headgasket or did you do it?
              Rimmers sell round hole gaskets that can be adapted for oval holes but you may get a little oil leak later, which is usual on an O series. You can remove the oval seal on your old gasket or buy a cheap oval hole gasket and put it on your round hole once you've removed the round copper seal and cut the gasket for the round seal to fit. Use a tiny bit of sealant round the seal and it should be ok. It can be done as i've had to do that in the past. Diesel manifold gaskets can also be adapted to fit if you need. If you're stuck i have a diesel manifold gasket spare
                Hi Jeff. Vinny did the head gasket but with my problem torque wrench which is where I think it has gone wrong.
                Adrian at XJ Rover has managed to sort me out with a turbo oval head gasket which is good news.
                Where you refer to the oval seal I’m trying to picture what you mean. I don’t recall doing anything other than putting the gasket on, then the head and torquing the bolts in the pattern you describe. Is there a further rubber seal to fit?
                  Its the oval oil way seal in tbe headgasket, can either be plastic or copper. Round oil hole was always copper.
                  Good to know adrian has a gasket for you. How far out was your torque wrench?
                    I’m not sure how far off it was. I know that after driving the car I could tighten the bolts in some cases as much as a full turn with the new torque wrench. I suppose it’s possible some of that would be the expected re-tightening but I think my wrench must have been a way off.
                      Ah that bad, the head would have lifted if running at speed if it was that far out, so yeah i would say it's gone.
                        Yes, it was wild optimism on my part that it would be a successful fix. Head off again.
                          At least it'll be easier this time. Should be all done in a day or if in no hurry, a weekend.
                            Yes. It’ll be like shelling peas! I don’t want to get up be an expert on it though … I want the thing to just flipping work!
