Leaving "Triple-M" Ownership
    Mal, the Triple-M landscape wouldn't be what it is now if you hadn't have been around, and it won't be the same in the future either.
    Good luck with it all.
    Ian
      mg maestro
      Either Mal,what is each one like ,I suppose the g efi is the most complete?will have a look if I can when I pick my bits up,if that's ok
        My White 28k Miles EFI after a fresh "Deep Clean" full valet.
        Not too happy about the surface corrosion that's appeared in some of the usual places, but still a stunner even after 20 months or so of being laid up.
        http://s236.photobucket.com/user/MGT...%202015?src=pb
        Hopefully a new home will be found in the near future.
        Norman,
        The G plate was given a partial restoration will all bolt on panels replaced with New, as well as a rework on various welded seems where the factory standard was "off".
        The car will be returning to the workshop to have some paint defects rectified, and then will be given a full "Deep clean " Valet and a new MOT before being listed as "Available".
        The J plate in the barn, is the one that was an abandoned project, small works required to finish off where the previous body man finished, then paint.
        Then it's a case of sorting/locating all missing parts and panel work before rebuilding.
        Or I may just strip it, as I have someone interested in the new steering and suspension set up it currently has fitted.
          How much is the efi 28k please Mal?
            its sold to me
            MG Maestro turbo 437
            367 Bhp
              Hi Mal - just curious as to what happened to the brand new o-series engine block that came with the 28k 2.0i? For sale perhaps?
              cheers
              mike...
                Originally posted by charliecosworth View Post
                its sold to me
                Cheeky!
                Not sold to anyone yet.
                • #23
                  What is the shell like on mental? I'm keeping my eyes open for a clean shell (not bothered about anything else) to build a 4wd maestro and considering the history of mental it might be nice to make it "mental" once again Since I've got 4 project cars on the go just now already I'm not saying im definitely going to buy it but if it's good and clean it would be a consideration.
                  All I will say is I WILL build a 4wd maestro one of these days but when it gets started in unclear just now
                  • #24
                    I would say Mental is "Salvagable" Shell wise, but will need work in usual area's.
                    Black efi rolling shell at the barn would be a better prospect as it has had new rear quarter, arch, and full sill fitted, as well as rear panel 'pro rebuilt" including new closing panels and lamp panels.
                    Link below to a few things I dug out of the loft rooms today, as well as the first in a long pile of box's I have yet to sort through and list to confirm identity of parts and quantity of each.
                    At least 95% of it genuine new rover/ MGR parts. Plastic Tubs all Maestro Montego.
                    (And approx 45% of the new parts I have here at home)
                    http://s236.photobucket.com/user/MGT...?sort=2&page=1
                    First couple of box's checked through:
                    Suspension and Steering:
                    ADU 9682 Drive shaft nut x 4
                    NAM 1479 Front Suspension bush (rear) x 10
                    NAM 3674 Front Spring Aid x 4
                    BEP 412 Cup -Rear-Suspension- Top Spring Mount x4
                    NAM 3961 Upper spring Insulator- front x7
                    NAM3962 Lower Spring Insulator - Front x2
                    FAM9457 Mounting Rubber Upper Strut Front x8
                    NAM 6928 Washer-Cup- Top - Front Strut x2
                    NAM 3958 Insulator -Upper Spring- Rear x1
                    NAM 1181 Bush-Large-Upper-Rear Strut x1
                    NAM 1180 Bush-Small- Upper- rear Strut x2
                    NAM 3580 Collar-Support-Rear Strut x2
                    FAM 9822 Bush -Front-Lower Arm x8
                    NAM 7152 Bush-Rear-Pivot- TURBO x2
                    NAM6929 Strut-Top- Cover-Front x5
                    FAM 8730 Bush-Lower-Rear-Damper Mount -Van x4
                    NAM 7150 Bush-Front- Lower Arm- TURBO x5
                    YXX 4745 LG Top Cover-Rear Strut x4
                    NAM 5694 Front-Roll Bar - Split Bush- TURBO x4
                    NAM 6924 Front Roll Bar Clamp Bolts -ALL x10
                    NAM 7355 Front Strut Top Ring-Nut -Bearing x1
                    NAM 4999 Spring Aid-Rear-Estate x2
                    GSJ 289 Ball Joint- Lefthand x4
                    GSJ 290 Ball Joint- Right Hand x4
                    GSJ 194 Track Rod End x5
                    FTR 4130 Track Rod End (Pattern) x5
                    GSV 1064 Drive Shaft Boot-Outer x1
                    SHA-CV17 Drive Shaft Boot-Outer (Pattern x1
                    Direct Parts - Pattern CV Joint (Outer) x1
                    GHK 1932 Front Hub Bearing (Solid) x4
                    GHK 1201 Rear Hub Bearing Kit x1
                    88G 520EVA Rear Hub Bearing Kit x1
                    QWB 594 Front Hub Bearing (QH) x1
                    GSV 1059 Outer Tie Rod Kit x2
                    TD/D Specific
                    GVC 7067 Montego TD/D Clutch cable x1
                    NAM 7907 Montego TD/D Throttle cable x2
                    BHM 1651 Main Bearing set TD/D 0.03mm Undersize x1
                    Crossland 5006 Fuel Filter TD/D
                    GWP 190 Water Pump Maestro (early) x1
                    NAM 5486 Hose-Rail to Heater D/TD x1
                    BDU 2381 Hose-Oil Drain-filler Tube to Reservoir D/TDx1
                    BDU 2261 Hose-Oil Breather - Filler Tube D/TD x1
                    GRH 880 Radiator Top- To Water Pump D/TD x1
                    GRH 1564 Hose- Pump Rear Top Outlet- To Thermostat TD/D x1
                    GTS 280 Thermostat -TD- 2 Stage Injection x1
                    Part 2
                    GBH 1053 Brake Hose -Flexi - Front x2
                    GBH 90263 Brake Hose - Flexi - Rear x2
                    NAM 7399 Throttle Cable RHD – EFI x1
                    CDP 6100 Bonnet Release Cable x2
                    NAM 3607 EVA Cable - Brake – Intermediate x2
                    GVC 5064 Cable – Clutch – EFI x1
                    GVC2337 Cable – Brake – Rear- Main – EFI x3
                    UUC 007064 EVA Cable – Clutch – EFI x3
                    GVC 7064 Cable – Clutch – Maestro 2.0 x1
                    GTB 801127A Drive Belt – O Series 2.0 x1
                    FAM 8560 EVA Cable – Brake – Rear x4
                    GVC 2069 Cable – Brake – Rear x2
                    GVC 2313 Cable – Brake – Front – EFI x1
                    ADU 6207 – Buffer – Cable – Clutch x5
                    DAM 5846 Support – Buffer – Clutch x3
                    PTCC 1279-Powertrain Clutch Cable EFI x1
                    PTCC 1375-Powertrain Clutch Cable Turbo x1
                    BC2031 Q&H Centre Brake Cable x3
                    MCC1602-Moprod Clutch Cable 2.0 x2
                    MCC7008-Moprod Brake Cable – Front x1
                    BC2070 Q&H Brake Cable - Front x1
                    VJB300 Cable – Centre – Brake x1
                    JRC2212 Seal – Grill – Maestro All x2
                    EAM 9033 Grill – Plenum – Left Hand – Maestro x1
                    EAM 9032 Grill – Plenum – Right Hand – Maestro x1
                    JRC 3709 Roof Rubber – Maestro Hatch x5
                    CZK 6649 Waist Seal x1
                    BEP 6136 LG Door Pocket – Right Hand – Front – Maestro x1
                    Part 3
                    CRC8136 Front Engine Mount Late EFI + 5 way Cat x1
                    CRC8727 Front Engine Mount EFI x2
                    CRC6445 EFI / 2.0 Carb Differential Mount x2
                    CRC8620 Gearbox Upper Mount LH x1
                    CDU2788 O/Side Heated Mirror Glass x3
                    CDU2787 N/Side Heated Mirror Glass x2
                    CDU2786 OS Mirror Glass Non Heated x2
                    JPC6063 Cigar Lighter Switch Panel x2
                    DBP6745PMF N/side Mirror Cover – Black
                    DBP6744NN O/Side Mirror Cover – White
                    JPC3756 O/Side Mirror Cover – Plain
                    FRAM4571/4952 Oil Filter – 2.0 x4
                    GFE6011 Oil Filler Cap – Genuine x11
                    GLP132 Oil Pump 2.0 – Various years x1
                    EEP92 2 Door Window Lift Unit x1
                    AFU4515 Wiper Switch – 4 Position 86-88 x3
                    LUF10002 Crank Shaft Oil Seal (Boxed) x2
                    DRC9109 Control Unit – Window Lift- 2 Switch x1
                    DBP6745NN N/Side Mirror Cover – White x1
                    DBP6745PMF N/Side Mirror Cover – Black x1
                    NAM3957 – Seat-Spring-Upper- Rear x3
                    AHU2947 Injector 2.0 – EFI x1
                    GFU2201 Flasher Unit – Vin 235830 onwards x1
                    GEX7626 Exhaust Rubber Mount x10
                    GCK552AF Clutch Kit 2.0 – EFI and D/TD 1990 onwards x1
                    GWP2862 Water Pump – EFI – Late Type x3
                    LRA461 Alternator – 65Amp x2
                    BAU5433 Heater Motor Unit & Fan x1
                    HSM423 Starter Motor – 20 – 88 0nwards – Halfords x1
                    CRC5039 Grommet – Fuel Filler – Rubber x1
                    YLG10001 Alternator Fan x1
                    GTB1127A Cam Belt 2.0 86 onwards x1
                    LHP10002 Cam Belt Tensioner 2.0 – TD –EFI x2
                    MC1571 Brake Master Cylinder x1
                    GMC244 Brake Master cylinder With Tank x1
                    GRK1015 Master Cylinder repair Kit x4
                    GRK1016 Caliper repair Kit x7
                    CDU3662 Pin Cover Set – Calliper Slide x2
                    GWC1157 N/S/R Wheel Cylinder x4
                    GWC1156 O/S/R Wheel Cylinder x4
                    QH- BWC3331 Rear Wheel Cylinder – RH x1
                    QH BWC3332 Rear Wheel Cylinder – LH x1
                    ATB4098 – Rear Hub Cap Grease – Retaining – All x6
                    • #25
                      Hi i will take the seat covers if still have them? (whats in your photos) are they front and rears or just fronts.
                      do you have any new grills (MG) ideally in white
                      and 2 anti roll bar link arms ( the small ones )
                      367 Bhp
                      • #26
                        Once I have everything listed I will deal with enquirie's in regards to selling.
                        I have a lot to get through and would rather get it all sorted rather than "Diving into box's for this and that".
                        Not sure on ARB "End" link bush's at the mo, which is why I need to confirm whats there first.
                        I had planned to sell all the general parts in one lot, which still may happen, but the more costly items such as covers and seats etc will still be sold separately.
                        Mal.,
                        I will let you all know once ready.
                        • #27
                          Damn! I could have done with those seat covers as well! Don't suppose you have the matching door cards to go with those do you?
                          Membership Secretary
                          • #28
                            no problem, give me first dibs on them.
                            Any news on the J reg MG Maestro, i have money burning hole in my pocket
                            367 Bhp
                            • #29
                              you can have my old ones. which are in great condtion
                              367 Bhp
                              • #30
                                Peter,
                                Having already had pictures up on F/book there are one or two who have already shown interest.
                                Sussex Pete.
                                I believe I do have a selection of MG maestro door cards, both early and late versions in good to great condition, but they are yet to be dug out and sorted.
                                I will apprise everyone of "progress and availability" on all items big and small as soon as I am satisfied I have found everything and listed them.
