R-series rocker cover bolt question
  • R-series rocker cover bolt question
    Hi all, thus metric/imperial/unf Click image for larger version
ID:	337178 bolt thread game has beaten me!
    what thread bolt was used to clamp down the rocker cover on my R series engine?
    Couldn't find thread size for you but EPC says part numbers are 53K1834 for the short one and 1842 for the long ones and there is a place that shows that part number for the Maxi engine. Parts list for Maxi shows 32B21 for the long bolt and 32B22 for the short ones. There is a place in Denmark that is advertising NOS of these bolts - probably Damen and Kroes. They are good but expensive. HTH
    Membership Secretary
      what size spanner did you use to remove them? was it a tight fit or loose?
        Loose 13mm or a tight 12mm, so hard inch was in-between.
          Brilliant, thank you again Pete.
            well 5/16" unf has 24 threads per inch, 5/16" unc has 18 threads per inch. I think it will be one or the other.
            is it just the bolt that you need or do you need an insert kit?
              They are 5/16" unf, don't think there are any metric threads on the engine itself.
                Hii Friends,
                I'd be happy to help with your question about R-series rocker cover bolts. Please provide me with more details on your specific question or concern.
                  Originally posted by Sophia78 View Post
                  Hii Friends,
                  Right, thank you kind lady.
                  what car do you own?
                    Spam mate
                      I know, was playing along Jeff.
