Thanks. I've BGB already - they were just asking so they could set the actuator I think.
Who rebuilds your T3 Turbo's?
Impressive! Looks like a company to remember.Club Secretary
i have used turborebuild a few times and they are excellent.. always do what they say, unlike some out there, they have supplied me with the new t3 for the mad maestro, i just need to get around to fitting it.. regards rickyhome of the "mad maestro"
rover sterling kv6 and four tailpipes on lenso rs5's
1935 Morris 18/6 being rejuvenated with xj6 parts
The information I was given is that a very small amount of in-and-out movement of the shaft was OK but any sideways movement was a no-no and would need a rebuild.Club Secretary
Its the other way around. There should/will be some minor radial play in the shaft (as the film of oil that the shaft floats on won't be there without oil pressure present). In/out (Longitudinal) movement of the shaft is usually a bad sign.www.maestroturbo.org.uk - The Tickford Maestro Turbo Register
