Who rebuilds your T3 Turbo's?
    Thanks. I've BGB already - they were just asking so they could set the actuator I think.
      Received back in under a week:
      Very impressed with their service.
      Ben
        Impressive! Looks like a company to remember.
        Club Secretary
          i have used turborebuild a few times and they are excellent.. always do what they say, unlike some out there, they have supplied me with the new t3 for the mad maestro, i just need to get around to fitting it.. regards ricky
          home of the "mad maestro"
          rover sterling kv6 and four tailpipes on lenso rs5's
          1935 Morris 18/6 being rejuvenated with xj6 parts
            I used turbo technics a few years ago, more expensive but I was happy.
              Hi chaps
              Don't know if you can advise but I have acquired a 2nd hand turbo that was possibly rebuilt and was wondering whether the shaft should be free of lateral play as there is some-or is that normal?
              TIA
              Phil
                The information I was given is that a very small amount of in-and-out movement of the shaft was OK but any sideways movement was a no-no and would need a rebuild.
                Club Secretary
                • #23
                  Its the other way around. There should/will be some minor radial play in the shaft (as the film of oil that the shaft floats on won't be there without oil pressure present). In/out (Longitudinal) movement of the shaft is usually a bad sign.
