......but having said that, and looking at estimated journey times I may change plans, set off far earlier and meet you at the B&Q - I'll keep you posted
Northern shows 2026
One or two pictures from Leeds, a good turn out, good weather and lovely gelato in the cafe https://www.themilkchurn.com/ a highly recommended place to drop into for a snack if you are anywhere near the A58 North of Leeds.
- 2 likes
At the moment Norman has a ticket & I have a ticket, Robert and Julie have emailed to try & get a ticket. If they don't succeed then we could meet you somewhere else if need be, Norman is not far away & I'm not too worried about the odd detour. I'll bring my circuit tester, so we can work out exactly what is wrong with your courtesy lights, if you don't get them working in the meantime, with the tester there is no guesswork involvedOriginally posted by Morris Montego View Post......but having said that, and looking at estimated journey times I may change plans, set off far earlier and meet you at the B&Q - I'll keep you posted
Thank you regards the circuit tester!
Looking at route planners and a good old fashioned road atlas yesterday, I'll be taking the tunnel from Wirral to Liverpool and then the A59 for Preston. Then the A583 and A584 for Lytham.
I have a SatNav which I am plugging into a battery pack and resting on my dashboard "tea tray". The rubber mat gives it grip, perfect! .....and, it probably has newer data than the 11 year old device built into my MG6!
I will have to set off earlier.....a 07:50 departure will cut things too fine - the gates close at 10:00am.
Lytham Hall tell me "there has been a flurry of Montegos" (and Maestros I assume) since my call!
York Historic Vehicle Group show at York Knavesmire on Sunday, the plan is to meet up at this service station (Bilbrough services) on the A64 eastbound at about 8.45AM, same as last year. https://www.google.com/.../data=!3m7!1e1!3m5... Postcode for anyone whose map has broken down & needs to use sat nav is LS24 8EG http://www.yhvg.uk/events
I shall be there. I will get there before the given time this time round I think as everyone was on the move when I turned up last timeOriginally posted by Doctordiesel77 View PostYork Historic Vehicle Group show at York Knavesmire on Sunday, the plan is to meet up at this service station (Bilbrough services) on the A64 eastbound at about 8.45AM, same as last year. https://www.google.com/.../data=!3m7!1e1!3m5... Postcode for anyone whose map has broken down & needs to use sat nav is LS24 8EG http://www.yhvg.uk/events
MG Maestro Turbo #500
Rover 218 VVC Coupe
MG TF
