Northern shows 2026
  • #61
    ......but having said that, and looking at estimated journey times I may change plans, set off far earlier and meet you at the B&Q - I'll keep you posted
    • #62
      One or two pictures from Leeds, a good turn out, good weather and lovely gelato in the cafe https://www.themilkchurn.com/ a highly recommended place to drop into for a snack if you are anywhere near the A58 North of Leeds.
      • #63
        At the moment Norman has a ticket & I have a ticket, Robert and Julie have emailed to try & get a ticket. If they don't succeed then we could meet you somewhere else if need be, Norman is not far away & I'm not too worried about the odd detour. I'll bring my circuit tester, so we can work out exactly what is wrong with your courtesy lights, if you don't get them working in the meantime, with the tester there is no guesswork involved
        • #64
          Thank you regards the circuit tester!
          Looking at route planners and a good old fashioned road atlas yesterday, I'll be taking the tunnel from Wirral to Liverpool and then the A59 for Preston. Then the A583 and A584 for Lytham.
          I have a SatNav which I am plugging into a battery pack and resting on my dashboard "tea tray". The rubber mat gives it grip, perfect! .....and, it probably has newer data than the 11 year old device built into my MG6!
          I will have to set off earlier.....a 07:50 departure will cut things too fine - the gates close at 10:00am.
          Lytham Hall tell me "there has been a flurry of Montegos" (and Maestros I assume) since my call!
          • #65
            Lovin' the Leeds photos!!
            • #66
              Planning to leave home, Wirral, Cheshire, at 07:00. Estimated journey time just under two hours. Meet you on the show ground
              • #67
                see you there...
                • #68
                  A few pictures from Lytham Hall, decent weather, decent grub, discounted entry to the Hall and good crack, another splendid day out.
                  • #69
                    York Historic Vehicle Group show at York Knavesmire on Sunday, the plan is to meet up at this service station (Bilbrough services) on the A64 eastbound at about 8.45AM, same as last year. https://www.google.com/.../data=!3m7!1e1!3m5... Postcode for anyone whose map has broken down & needs to use sat nav is LS24 8EG http://www.yhvg.uk/events
                    • #70
                      Sounds good!
                      • #71
                        I shall be there. I will get there before the given time this time round I think as everyone was on the move when I turned up last time
                        MG Maestro Turbo #500
                        Rover 218 VVC Coupe
                        MG TF
                        • #72
                          I'll try to do a more accurate turbo count this time & pay less attention to anyone that says everyone is here!
                          • #73
                            That was another good day. Not a great start forgoting my ticket and the unexpected morning rain but it got out glorious. Did the AA come back and take Norman on his way home ok?
                            Rover 218 VVC Coupe
                            MG TF
                            • #74
                              Yes, the second AA bloke had been at Locke Park & remembered us!
                              • #75
                                We are getting a bad reputation Glad he got on his way home safe.
                                Rover 218 VVC Coupe
                                MG TF
