MG Montego Turbo goes
  • #61
    Curse of Andy struck again today.
    Petrol vent pipe done.
    Fuel filter on
    Spark plug leads on
    Coil connectors fitted and on
    Turn car over and......no spark
    Remove distributor cap and the grub screw for the rotor arm wasn't in properly and is cross threaded.
    Cam seal also has a leak so will fix both and try again.
    Fuel pump doesn't prime so that's a problem to be sorted.
    Will also have to change the starter motor as it's making clicking noises as it turns the engine over and the relay is clicking. Perhaps the wrong teeth amount.
    • #62
      not been on road since 2010
      • #63
        Cam seal sorted, Cross thread fixed, new rotor arm, distributor cap on.
        Carb on and all fixed up.
        Put the battery on, put fuel in the tank, poor a little into the carb and ................nothing, still no spark.
        Changed the coil, ignition ecu and still no spark so will take my fast check and voltmeter next time to find out what's wrong.
        Fuel pump still not priming
        Also the starter motor and relay are 'clicking' when it turns over the engine, not sure atm what's causing this.
        • #64
          could this be that safety switch that's needs resetting?
          not sure what it turns the power off to.
          it behind the radio?
          red with a plunger on top?
          Tony Hague
          • #65
            Inertia switch tony. Already swopped that for another incase that was faulty.
            Will have to use my fast check and voltmeter probably to find the problem
            • #66
              well done jeff nice to see your work.with all the dismanteling of all the parts.i know this mite seem a silly thing but have you checked the earth wireing engine earth and componet earth wire/connection to body work as some time a car being out of service can corrode.
              • #67
                Not yet Dave, didn't get long on it as I was also selling 2 MG Montego's from my barn and that took time as both had duff batteries.
                They're being picked up soon so I can spend sometime on it. Probably something silly as I replaced the whole wiring loom
                • #68
                  Left to do
                  Sort clicking starter and relay
                  Fit complete exhaust from my spares. Rear box to do
                  Put petrol in it
                  Sort no spark. Hopefully found
                  Sort non priming
                  Re-connect boost pipes
                  Attach Plenum
                  Put the dash in,
                  Do headlining
                  Put front carpet and front seats in
                  MOT
                  The list is getting smaller
                  • #69
                    Yep, deffo crank sensor, supposed to light up. When switched to dynamic and crank the engine over it still doesn't light up.
                    • #70
                      As ive now sorn my digidash I can now concentrate on this car.
                      Sooooo Andy strikes again.
                      Had to remove the inlet and exhaust manifold to get to the crank sensor.
                      2 bolts were loose so in a way it did me a favour.
                      Before putting a replacement sensor I checked it and it's working.
                      New sensor on and didn't bring a spare manifold gasket with me. Buggar as I was also wanting to put the dash in. Oh well will put to gether on the next trip
                      • #71
                        All back on now and the car now starts if I put fuel into the carb.
                        Will put a couple more gallons into the tank and see how that goes, if the fuel pump still wont prime I will change the oil pressure switch
                        Will also be checking the fuel ecu etc before finally putting a dash in.
                        Also fixed the 'clicking' when trying to start the car, I hadn't tightened up the front offside earth lead enough. Good call BIGDAVE
                        • #72
                          What's the plan Jeff, put it back on the road as it is or is there bodywork to be done beforehand. Sounds like its nearly there in the main tho, be great to see another around the area
                          • #73
                            Hi John
                            Long time no see, plan is to put it back on the road and to also teach my youngest how to do it.
                            and it's about time you got yours sorted
                            • #74
                              Dash finally going in
                              Radio wiring sorted with replacement loom from my spares
                              • #75
                                Did you hit your deadline?
                                Looks a nice car.
