1984 MG Montego Efi with digidash
  • Headlining biscuit now strengthened
    Levelled off the press in studs
    Heads nearly flush but i'm happy with it
    • Drivers door wiring in and all tidied up
      New rubber
      • Centre consol.
        As the original had previously been broken i've had to replace it.
        There are differences in early and later centre consols
        As early cars have this. A vent running from the heater unit that was dropped a couple of years later
        • Remove all retaining screws
          Mark up
          First cut
          • Check fit
            Swop retaining bracket
            All done and ready to go in, just needs a strip of foam on the front so it doesn't rattle
            • Door cards
              Early door cards have the retaining clips inserted into polystyrene blocks that are stuck on to the door card
              These break very easily
              • Other the years 'collecting' spares I have a full set of door cards to replace these with the later retaining clips and screw holes
                Next job change the card centres and drill some holes in the doors in strategic places.
                The door card centres on this car have the electric window switches inserted
                • Differences in the door cards continued
                  Later ones have these brackets on
                  Early top fixing
                  Later top fixing
                  • Early cars also have bolts on the speakers
                    Later have self tappers, all are held with these fixings
                    Centre removed
                    • Fingers inserts are glued on
                      Both done with the exception of the finger inserts as both were damaged. I have more somewhere
                      • Superb work Jeff. I just love the Marle Deco interior.
                        • This car will be absolutely outstanding and will compliment your black Turbo, great work and although i haven't commented on this thread before - believe me i've been reading it with great interest!
                          • Looking good. I never knew those switches were meant to go there . On my dads old c reg vanden plas it had the switches fir the windows under the radio in the centre console.
                            • Thanks for the comments guys.
                              Thomas, on early cars if you only had the front electric windows the switches were on the door cards, if all 4 were electric the switches were in the centre consol as on your dads car.
                              All switches were moved to the centre consol from late B reg/early C reg.
                              I could easily have converted the switches to the centre as its simple wiring and its taken me a while so sort this but was trying very hard to keep them in the door cards and I'm happy I've finally fixed it
                              • Prezzies arrived while i've been working away
                                Interior light, although a little too long i think it's a great match and I can experiment with it
