1984 MG Montego Efi with digidash
  • #61
    The servo looked like this when its was on the car
    Now looks like this with one coat left to do
    New alternator found so I will start to put it all back together next week, hopefully
    • #62
      Certainly looks brand new now Jeff - are you going to detail the rest of the engine bay?
      • #63
        Left to do
        Fix fan resistor DONE
        Convert newer dash to older. DONE
        Replace nearside electric window motor. DONE
        Re-wire drivers electric window loom.
        Convert manual to electric mirrors? DONE
        Modify and replace front door card fixings.
        Replace dash, heater etc. HEATER ON
        Replace centre consol.
        Wire in radio loom
        Replace front seats
        Replace seat belt stalk
        Replace rear lap belts from grey to red. NOW GOT
        Add wiring and lighting to headlining. DONE
        Headlining
        Replace servo. DONE
        Replace alternator. NEW FOUND
        Paint engine
        Clean engine bay
        Replace cambelt, tensioner. REMOVED
        Engine service
        Weld rear sill
        Replace all tyres. GOT A SET SPARE
        Replace exhaust. Have a new one
        Rub down door pillars and paint
        MOT
        • #64
          Meeee? detail??? nope not my style Mike.
          I will clean the engine bay up over the winter but its a car that will get dirty once its on the road.
          • #65
            Was this one of the cars with the yellow engine? I remember the first maestro EFi is saw had a yellow block
            • #66
              As the engine is a faded red I wouldn't have thought so Russ
              • #67
                So the time is nearing when you have to break news of the purchase to the wife
                • #68
                  Stop it, I haven't told her about the red digidash yet
                  • #69
                    Bit more done today before I have to go to work
                    The foam on the heater has perished so it needed replacing as I don't want any leaks or whistles
                    So I got some of this
                    First rough cut
                    Used this to stick it done after I have cut the inside
                    Just waiting the final trim
                    And thick enough
                    • #70
                      The matrix foam had also perished
                      Wont rattle now
                      I still have a couple of foam parts to replace and will do those when I'm next working on the car
                      • #71
                        Progress now as things are going back on/in the car
                        Heater in
                        Matrix back in
                        Pipes and main loom clipped back on
                        No foam here
                        • #72
                          Left my scissors at home so had to use a knife to trim
                          I've not seen a self tapper here before
                          All on
                          Dash finished off as I hadn't screwed this back
                          • #73
                            Servo back on
                            Alarm removed
                            All pipes re-connected
                            • #74
                              Electric mirror wiring is in here somewhere
                              Found some of it
                              All found and removed. Only one side is working so I will have to check on the connections. I have 2 brand new mirrors waiting to go on the car
                              Engine next to do.
                              Cambelt, tensioner, oil, filters, engine clean and paint, then put back on the alternator
                              • #75
                                Left to do
                                Interior
                                Replace dash
                                Replace centre console
                                Re-wire front electric windows
                                Re-attach front seats
                                Re-attach seat belt stalk
                                Modify and replace front door card fixings. STARTED
                                Wire in radio loom
                                Headlining. STARTED
                                Engine bay
                                Paint engine
                                Clean engine bay
                                Replace cambelt, tensioner: They're off
                                Replace coreplugs. GOT
                                Engine service
                                Body etc
                                Weld rear sill. JUST BOUGHT A WELDER
                                Replace exhaust. HAVE A NEW ONE
                                MOT
                                The list is getting smaller with every visit
