1984 MG Montego Efi with digidash
    There was an early black rear spoiler on ebay a day or so ago if that helps.
      Thanks but I don't need it as I have 2 spare. The only thing I will need for the car is the wiring loom made up from the connecting plug to the radio, dark grey headlining material but I should have all other things in my spares stash
        Did some work on this today
        Will have to change this soon
        Something is missing here as I have to change it
        It's hidden under here
        Can only remove it from under the car
        Had to remove the bracket to get it out, stupid place to put it and I can see why they moved the alternator to the front, note the pulley difference
        Heat shield still in place
          Next was to replace the broken spoiler, there are 2 types, adjustable studs
          Fixed studs
          Fixed studs has Austin/Rover on the spoiler adjustable has nothing
            Much better
            Next was the missing Montego badge
            Rear is finished
            Front indicator fixed
              Amazing how that front indicator managed to fix itself! LOL.
                Originally posted by MG MAL View Post
                Amazing how that front indicator manager to fix itself! LOL.
                Yep, when I last saw it the cover wasn't there, now it is and I didn't touch it, ta Mal
                • #23
                  Nice spoiler jeff
                  • #24
                    Originally posted by MGRick View Post
                    Nice spoiler jeff
                    See what ya did there Rick, good to have mates eh
                    • #25
                      Re-furbed alternator sorted and ready to put on.
                      I will be trying to find my spare 'oneshot' drivers electric window regulator as it's somewhere in one of my spares stashes to get the electric windows working, it's either that or a relay that needs replacing.
                      After that remove the headlining
                      • #26
                        While I was working on my white Turbo project all friday I didn't get a chance to continue this project, but I did cut a section of the headlining and will match it with something from the NEC, hopefully
                        • #27
                          New alternator now on, that took over an hour
                          Now says this instead of alternator fault and after a few minutes it's fixed
                          • #28
                            Now the alternator has been replaced I can try and fix the electric windows
                            This had been mullered
                            So I managed to get a replacement
                            Connected and....nothing.
                            Checked the fuse, thats ok so I checked the relay and found this
                            No idea why the second relay in the door has had the wires cut.
                            • #29
                              Turned the lights on and it shows, lamp faults with the lamps working, the outer rear lights had the bulbs missing so I but new bulbs in. The offside cluster blows the outer lamp so I think an earth problem here.
                              The alarm indicator comes on sometimes so again possibly an earth fault.
                              I will be removing the dash and nearside door card next as neither front electric windows are working and it blew a fuse when I tried the nearside wiindow, again possibly an earth fault.
                              • #30
                                Will soon be taking it's place in the GSI's empty garage just around the corner from me so I can have more time to fix it up
