Looks like its coming home next month to be swopped with my red digidash
Cars being swopped tomorrow so I had to get this one ready. Had a little bit of time so I fixed a couple of things.
All lights work now, I replaced both clusters from my spares and hey presto
All confirmed as working
Alternator I put on it is making a bit of a noise to I will have to replace it, its charging but one of the bearings must be gone or the belt is too loose.
Electric windows sort of work now but not how they should, I have started to uncover the wiring and once the dash is removed I should find the problem.
I'm looking forward to spending a couple of solid days on this
A little progess today as I have to work later
Dash removed and what a pain with the alarm wires wrapped round everything, took me over an hour to remove it. alarm disconnected and binned
Sorting electric windows
Got the passenger side working but the drivers still refused to work properly so i will rewire it and bypass the 'one shot' unit.
Heater has to be removed as the resistor isn't working next.
Broken but have a spare
This has been repaired in the past
Got a brand new one or this as a replacement
I noticed that the seats are faded so I replaced those
Normally a clip here but not sure if this was how it started with a large self tapper as there was still plastic covering on it
Big cracks on the original dash
Vent differences, old dash seems more cluttered
Older dash has the fuse box surround on it and you have to remove the steering column to get it out. I might try to convert the newer dash to include the fuse box surround, just to be brave enough to cut into it
Radio lamp on older types and additional strip of plastic for the speaker front/rear control
I will have to remove the heater while the dash is out to replace/fix the resistor as the fan only works on full.
Left to do
Fix fan resistor DONE
Convert newer dash to older. DONE
Replace nearside electric window motor. DONE
Re-wire drivers electric window loom DONE
Convert manual to electric mirrors? DONE
Modify and replace front door card fixings DONE
Wire in radio loom DONE
Replace dash DONE
Replace centre consol DONE
Replace seat belt stalk DONE
Replace front seats DONE
Replace rear lap belts from grey to red DONE
Add wiring and lighting to headlining. DONE
Headlining DONE
Replace servo. DONE
Replace alternator DONE
Paint engine
Replace cambelt, tensioner DONE
Engine service DONE
Weld rear sill DONE
Replace all tyres DONE
Replace exhaust DONE
MOT DONE
