look forward to seeing this finished. i would love one of these or a 1985 turbo. I see the service light is on, how do you go about reseting that?
By the way i have a brand new rear light bulb check module for one of thoses should you need it
Guest replied
Needed for the car
Rear bumper (have 2 spare)
Bootlid (have a spare)
Front door cards (have 4 spare)
All 4 doors, the drivers door has had an outer skin put on it but it didn't had enough paint put on it so it's slowly rusting. (I have 4 good spare doors)
All door windows as all have been heavily scratched. (not sure if I have a set that doesn't have a number plate sketched on)
Bonnet (have 2 spare)
Front bumper brackets as they have rotted through (have spares)
Centre consol tray (have a spare)
Wipers (have spares)
Dash (have spare but not early one)
Rear seats (have all four seats spare if needed)
Front crash panel rusted (have spare)
Brake servo (have spare)
Aerial (have spare but newer type)
Radiator is shot (have a new spare)
Rear parcel shelf (have 2 spare)
Both drip trims on the roof (have crome spares only)
Drip seams will need work as they are rusty
Headlining looks as though it's been re-covered, but it hasn't been put back correctly.
Drivers door rubbing strip (have spare)
Both rear arch rubbing strips (friend has one)
Exhaust manifold is cracked (have a spare at Mal's barn)
Head is leaking oil so will also change the head gasket. (have loads of these)
It's had both front wings replaced at some point but the top bolt on the drivers side is missing so will look at that more closely when I remove the drivers door.Last edited by Jeff Turbo; 9th April 2012, 13:39.
Note the rear black seatbelts, fronts are red
Fronts seats just need a clean really but I have 2 spare
The projects next to each other
My sons Turbo projectLast edited by Jeff Turbo; 9th April 2012, 13:40.
Note the switches on the door cards
Plenty of thick wiring and a relay in the door
Note the old style dash
Note the longer 'one shot' drivers window switchLast edited by Jeff Turbo; 9th April 2012, 13:40.
Got the electric windows working
Got central locking working on 3 doors
Went and had a proper look round the car today and listed a few things that came with it including my prezzy from Mal.
New Throttle body
New ECU
All four wheels have been re-furbed
New horns
New rear plinth
New outer CV unit
New boot lock mechanism
New rear brake cylinders
2 new front wheel bearings
New front MG badge
2x new front electric window mechanisms
New heater dash display
New rear seat base coverLast edited by Jeff Turbo; 9th April 2012, 13:31.
Originally posted by PatrickIngham View Postbring it to BL day on a trailer Jeff!
I will post updates when I do things to it, will be having a proper look see about mid April as it's the earliest I can get there and will take more pictures etc
Guest repliedI really want to see a digi-dash monty, bring it to BL day on a trailer Jeff!
Originally posted by Captain Slow View PostWill it be at any shows this year do you think, Jeff?
Originally posted by MG MAL View PostIt has been delivered! (1930 hours last night!)
Started up straight away then tick tick tick, manifold and exhaust blowing, leccys windows not working and a few other things to work on but it's not too bad and nothing I can't sort.
Came with half a tank of petrol, some spares and a birthday prezzy from Mal and Fiona. Many thanksLast edited by Jeff Turbo; 27th March 2012, 17:42.
Guest repliedIt has been delivered! (1930 hours last night!)
Originally posted by G51 NAV View PostThe only one I've ever seen 'in the metal' was a black one, also B-reg, at MGSD in 2003: reg B925 UPP. Despite looking pretty decent as I remember it back then, it's not been taxed since May 2007, so it's probably dead.
Originally posted by mgblack View PostWell done Jeff great to see this car find a proper home, really looking forward to seeing it, about time you found yourself a project
Originally posted by chrisl View PostWell done Jeff!
C
The car will be picked up soon and I will post up more pictures then and also updates on my progress.
It shouldn't take too long as it's mostly to replace the bolt on panels, trim etc then a spray.
I should have everything in my spares for it and I know a good sprayer/bodyman from the forum and he's agreed to take it on when I have finished what i need to do first
I want to put an MOT on it first to see what needs to be done other than the body.
The car won't be rushed as don't have a lot of time but it should be done by the summer all being well.
