  • Front and rear bulb monitors, rear on the left front on the right
    • As i suspected the Monitor was at fault, all working now, tidied up the wiring round that as i'd stripped it down. Couldn't understand why when I put the cowling on the slot in the wiper/indicator stacks wouldn't catch the steering wheel, till I got another and one was a little smaller, done that now. Cowling on, steering wheel near on till I drive it to centralize, front mats in as is the dash mat.
        Although it's near completed there is still quite a lot to do
        Attach dash side trims and bolt covers---DONE
        Position Vin plate--DONE
        Get radio fixed
        Attach rear view mirror---DONE
        Drill holes for door cards-- DONE
        Attach door plastic insulation-- DONE
        Attach door cards - - DONE
        Attach number plates--DONE
        Bleed brakes---DONE
        Clear boot and put trim in---DONE
        Put new jack etc in---DONE
        Sort speakers--DONE
        Sort tracking
        Shake down
        MOT
        Think thats all of it
        Getting near the finish now
        • Well that was a bummer, bleeding the brakes and leak from a joint I hadn't looked at, made a replacement pipe now so that to fit after i've sorted the intercooler pipes on my MGZTcdti that are leaking oil
          • After a bit of difficultly bleeding the brakes, had to use gravity method in the end as the air wouldn't come out. Now the car finally moves and stops under its own steam. Paint needs a major clean atm but I not doing that till its finished, I've also attached the drivers door mirror today. On another note, only one fault and red light left to sort on the dash, low washer fluid, happy days
            • Passenger door completed and came out much better than I expected, new battery clamp and dip stick on, rear view mirror on, dash caps on, two speakers on, vin plate attached, boot cleared out, spare wheel and jack in boot.
              • Interior all in, new clips used
                • After 8 years of ownership this will be a nice place to be as I've never driven it on the road, speakers all connected, big clean up next, then number plates and hopefully an MOT soon as nearly completed. Happy happy happy
                  • Nice one Jeff.... Inspirational.
                    • Great attention to detail, time to enjoy the car.
                      The montego really was a clean shape and all the better for it.
                      • Now ready for its mot
                        • And I polished it
                          • Interior cleaned
                            • All very shiny
                              • Even did under the bonnet, though that was a faff. Bonnet wouldn't open so I had to undo the bonnet catch and reposition it, sorted now. Radio isn't plugged in as i'm waiting for it to be repaired. I'm in love now with this car and hopeful of a favourable MOT when my MOT man is back soon.
